4.Technical Specifications ​
Vacuum GripperVacuum Gripper
Rated Supply Voltage24V DCPayload (kg)≤5kg
Absolute Maximum Supply Voltage28V DCNoise Level (30cm away)< 65dB
Max negative pressure-55kPaQuiescent Current(mA)20mA
Vacuum Flow (L/min)> 4L/minPeak Current(mA)500mA
Weight (g)620 gCommunication ModeDigital IO
Dimensions (L*W*H)122.5 * 91.6 * 75mmState IndicatorPower, Working State
FeedbackAir Pressure (Low or Normal)
