5. Errors and Handling ​
5.1 Error Codes ​
Software Error CodeAlarm CodeHandling Instructions
G10x01Gripper G2 FOC operation timeout, please clear the error and try again.
G20x02Gripper G2 overvoltage.
G30x03Gripper G2 undervoltage.
G40x04Gripper G2 overheating.
G60x06Gripper G2 Gripper G2 speed feedback fault.
G70x07Gripper G2 Overcurrent. Please click "OK" to re-enable the gripper.
G80x08Gripper G2 MCSDK software error.
G90x09Gripper G2 driver protection.
For alarm codes not listed above: Re-enable the robotic arm and gripper. Contact technical support if errors persist.
5.2 Error Handling ​
5.2.1 Clearing Errors via UFACTORY Studio ​
  1. Power cycle the robotic arm using the emergency stop button on controller.
  2. Enable the arm: Click the guide button in the error popup or the enable button on Live Control page.
  3. Select Gripper G2 and control.
5.2.2 Clearing Errors via xArm-Python-SDK ​
Clearing steps: (Python-SDK API)
  1. Power cycle robotic arm using emergency stop button
  2. Clear errors: clean_error()
  3. Re-enable arm: motion_enable(enable=True)
  4. Set motion mode: set_mode(0)
  5. Set motion state: set_state(0)
  6. Enable Gripper G2: set_gripper_enable(enable=True)
Python example:
import os
import sys
import time
arm = XArmAPI('192.168.1.68')
arm.clean_error() # Clear errors
arm.motion_enable(enable=True) # Re-enable robotic arm
arm.set_mode(0) # Set motion mode
arm.set_state(0) # Set motion state
arm.set_gripper_enable(True)  # Enable Gripper G2
