8.Appendix-UFACTORY Private TCP protocol control ​
This section mainly explains how to control the BIO Gripper G2 by using the Modbus-TCP protocol through xArm control box.
8.1 UFACTORY Private TCP protocol ​
8.1.1 Register Address Description ​
Refer to 4.Modbus-RTU Communication Protocol Control
Modbus-TCP:
Modbus protocol is an application layer message transmission protocol, including three message types: ASCII, RTU, and TCP. The standard Modbus protocol physical layer interface includes RS232, RS422, RS485 and Ethernet interfaces, and adopts master / slave communication.
The BIO Gripper G2 supports the private TCP protocol, which is similar but not identical to the standard Modbus TCP.
Private Modbus TCP Communication Process:
  1. Establish a TCP connection
  2. Prepare Modbus messages
  3. Use the send command to send a message
  4. Wait for a response under the same connection
  5. Use the recv command to read the message and complete a data exchange
  6. When the communication task ends, close the TCP connection
Parameter:
  • Default TCP Port: 502
  • Protocol: 0x00 0x02
On the problem of users using communication protocols to organize data in big endian and little endian:
In this article, data analysis is big-endian analysis.
8.1.2 Read BIO Gripper Register ​
Register Function
Read Register
Request
MBTP HeaderTransaction Identifier2 Bytes0x0001
Protocol Identifier2 Bytes0x0002
Length2 Bytes6+N*x2
Unit Identifier1 Byte0x7C
Internal UseInternal Use1 Byte0x09
Modbus RTU DataSlave ID (Gripper)1 Byte0x08
Function Code1 Byte0x03
Register Starting Address2 BytesAddress
Quantity of RegistersN*x2 BytesN*
Response
Length2 Bytes6+N*x2
Status Value1 Byte0x00
Modbus RTU DataSlave ID1 Byte0x08
Byte Count1 ByteN*x2
Registers ValueN*x2 BytesValue
N* = Quantity of Registers
Address = Register Starting Address
Register Function
Resgister Starting AddressRegisters Value
Get Gripper status Register0x00002 BytesDisabled: 0x0000 Enabling: 0x0004 Enabling completed: 0x0008 Stop status: 0x0008 Motion status: 0x0009 Clipping status: 0x000A Error status: 0x000B
Get Gripper Error Register0x000F2 BytesAn error occurs: all other return values indicate an error(except 0)No error occurred: 0x0000
8.1.3 Write BIO Gripper Register ​
Write Register
Request
Length2 Bytes9+N*x2
Function Code1 Byte0x10
Quantity of Registers2 BytesN*
Response
Length2 Bytes0x0009
Resgister:
Resgister Starting AddressRegister Value
Enable/Disable Gripper Register0x01002 BytesEnable : 0x0001 Disable : 0x0000
Set Gripper Position Register0x07004 BytesOpen the Gripper : 0x0000 0x0082 Close the Gripper : 0x0000 0x0032
Set Gripper Speed Register0x03032 Bytes0x0000-0x0BB8
Clear Error Register0x000F2 Bytes0x0000
8.1.4 Private TCP Example ​
Use private TCP to control BIO Gripper G2 opening and closing, mode 0.
  1. Set the Bio Gripper G2 mode 0. Address: 0x010A, still effective after power failure.
Send:00 01 00 02 00 08 7C 09 08 06 11 0A 00 00
Response:00 01 00 02 00 09 7C 50 09 08 06 11 0A 00 00
  1. Enable the Gripper. Address: 0x0100
Send:00 01 00 02 00 0B 7C 09 08 10 01 00 00 01 02 00 01
Response:00 01 00 02 00 09 7C 50 09 08 10 01 00 00 01
  1. Open the Gripper
Mode 0 has no position control, sending position > 90, then opens the Bio Gripper G2. (OCT)130=(HEX)0082
Send:00 01 00 02 00 0d 7C 09 08 10 07 00 00 02 04 00 00 00 82
Response:00 01 00 02 00 09 7C 50 09 08 10 07 00 00 02
  1. Close the Gripper
Mode 0 has no position control and sends a position ≤ 90,then closes the Bio Gripper G2. (OCT)50=(HEX)0032
Send:00 01 00 02 00 0d 7C 09 08 10 07 00 00 02 04 00 00 00 32
