5. Error Handling ​
5.1 Error Code ​
Error codeDescriptionError handling
BG01FOC Run TimeoutBIO Gripper FOC run timeout, please clear the error and retry.
BG02Over Pressure ProtectionBIO gripper over pressure, please contact technical support.
BG03Undervoltage protectionBIO gripper gripper undervoltage, please contact technical support.
BG04Overheating ProtectionBIO Gripper overheating, please contact technical support.
BG05Startup FailureBIO Gripper startup failure, please contact technical support.
BG06Speed Feedback FailureBIO gripper speed feedback fault, please contact technical support.
BG07Overcurrent ProtectionBIO gripper overcurrent, please contact technical support.
BG08MCSDK Software ErrorBIO gripper MCSDK software error, please contact technical support.
BG09Drive ProtectionBIO Gripper drive protection, please contact technical support.
BG11Gripper OvercurrentBIO Gripper current is too high. Please click 'Confirm' to re-enable the gripper. If the error is reported repeatedly, please contact technical support.
BG12Gripped Object SlippedBIO Gripper Error. the BIO gripper gripped object slipped, please clear the error and retry.
5.2 Error Handing ​
5.2.1 Cleaning errors with UFACTORY Studio ​
  1. Re-powering the robotic arm via the emergency stop button on the control box.
  2. Enable robotic arm. xArm Studio enable mode: Click the guide button of the error pop-up window or the ‘Enable’ blue button in the upper right corner.
  3. Re-enable the gripper: Select the BIO gripper G2 and click 'Enable'.
5.2.2 Cleaning errors with xArm-Python-SDK ​
When designing the robotic arm motion path with the Python library, if the robotic arm error (see Appendix for Alarm information) occurs, then it needs to be cleared manually. After clearing the error, the robotic arm should be motion enabled. Python library error clearing steps: (Please check GitHub for details on the following interfaces)
Clear the error step:
  2. Error clearing: clean_error()
  3. Re-enable the robotic arm: motion_enable(enable=True)
  4. Set the motion state: set_state(0)
  5. Set the motion mode: set_mode(0)
  6. Enable BIO Gripper G2:set_bio_gripper_enable(enable=True)
Python Example:
import os
import sys
import time
arm = XArmAPI('192.168.1.75')
arm.clean_error() #clean error
arm.motion_enable(enable=True) #re-enable the robotic
arm.set_mode(0) #set motion mode
arm.set_state(0) #set motion state
arm.set_bio_gripper_enable(enable=True) #enable bio gripper G2
