4. Error Handling ​
Controller Error CodeCode(HEX)Error Handling
C500x32Six-axis Force Torque Sensor Error
Please check the sensor error code, locate the problem, and power on again. If it cannot be resolved, please contact technical support.
C510x33Six-axis Force Torque Sensor Mode Setting Error
Please make sure that the robotic arm is not in Manual Mode, check whether the given value of this command is 0/1/2.
C520x34Six-axis Force Torque Sensor Zero Setting Error
Please check the sensor communication wiring and whether the power is normal.
C530x35Six-axis Force Torque Sensor Overload
Please reduce the payload or applied external force.
C540x36The six-axis force torque sensor detected a collision.
Sensor Error CodeCode(Hex)Error Handling
F640x40Six-axis Force Torque Sensor Communication Failure
Please check whether the wire between the Data Collector and the Six-axis Force Torque Sensor is connected properly.
F650x41The Data detected by the Six-axis Force Torque Sensor is Abnormal
Please contact technical support.
F660x42Six-axis Force Torque Sensor X-direction Torque Exceeds Limit
Please reduce the force applied in the X direction.
F670x43Six-axis Force Torque Sensor Y-direction Torque Exceeds Limit
Please reduce the force applied in the Y direction.
F680x44Six-axis Force Torque Sensor Z-direction Torque Exceeds Limit
Please reduce the force applied in the Z direction.
F690x45Six-axis Force Torque Sensor Tx Torque Exceeds Limit
Please reduce the torque applied around the X axis.
F700x46Six-axis Force Torque Sensor Ty direction Torque Exceeds Limit
Please reduce the torque applied around the Y axis.
F710x47Six-axis Force Torque Sensor Tz direction Torque Exceeds Limit
Please reduce the torque applied around the Z axis.
F720x48Six-axis Force Torque Sensor Configuration Write Failed.
F730x49Six-axis Force Torque Sensor Failed to Initialize
Please check
1. Whether the baud rate of the Data Collector and the Six-axis Force Torque Sensor are the same.
2. Whether the wire between the Data Collector and the Six-axis Force Torque Sensor is connected properly.
F740x50Six-axis Force Torque Sensor is initializing.
